Untitled
Untitled
F
FAO Daz
Toys!
Just been doing a trial go with the power wire.
The box at the top is the PSU. The big boxes are the amps, top one rated 1.2kW total and the bottom one 0.6kW (RMS) but they are actually identical apart from the crossovers.
Re: Re: Re: Untitled
why do you need a seperate power supply? Is it to change the voltage or just to stabalise teh output?
Re: Re: Re: Re: Re: Re: Untitled
Are they 14v, 16v or 24v?
Daz
Re: Re: Re: Re: Re: Re: Re: Untitled
+/- 36v :)
The amps themselves have no PSU in them.
Re: Re: Re: Re: Re: Re: Re: Re: Untitled
I ammend my original comment...
Holy Fcuking ****! :)
Won't you need a yellow/red top (or similar) to keep your battery from boiling?
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
Nah, its only fused at 80A. As the PSU is external it can be BIG and is alot more efficient than a normal amp.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
Aren't you worried about your lights dimming?...or wont that happen with your set up?
I only ask, as at the moment i only have 1 amp + 1 sub (Apline V12 bridged at 320wrms into a infinity perfect 12" sub), and my lights dim if i turn the volume to half way...even at half way its not that loud, and if i turn it up to about 3/4 i dont get any distortion but my radio cuts out... (doesnt turn off, just the sound stops, usually when the bass kicks in)
My volume goes from 0-30, and even at 8-12 if i turn my indicators on my lights and milometer lcd dim with the flashing...
I was going to have a look at checking/beefing up the earth points on my H-unit, amp, battery etc... on the weekend, do you think this will cure it?
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
I've got a Varta 63Ah battery to go in and I'm also going to upgrade all the engine bay wiring as its a bit crap really.
I'm not worried about lights dimming ;)
No speakers will be run from the HU.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
Where do you think i should start with mine?
Maybe i could pop down sometime and have a look at yours? :)
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
I'll try and remember to take pictures. I was going to photo the wiring before I put the centre console back but it was getting dark and I was in a hurry.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
A simple no, would have sufficed...lol
no probs mate...i will just have to until the photos have been published :(
Daz
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Untitled
Its more a case of I have no idea when I will have the time to do it.
C
3
7K
Tommy K
T
2
6
500
paull
P
539
dexter
C
1
600
Chris
C
O
2
435
orangebravo
O
