General  uno turbo
General  uno turbo
I think an UT for that price is too good to be true. They are extremely rare nowadays, especially the mark 1s! To get a decent UT you would need to expect to pay somewhere between 1000 to 1500 pounds.
If it is priced that cheap you need to check the bodywork very closely, look for rust under the arches, especially inside the car (under the carpet in the rear) where the suspension towers are as this is a common place for it to occur. Also check around the sun roof, under the bonnet etc. Rust on doors or bonnet doesnt mean walk away as it can be cured easily but if you see any rust on the chassis then you may be in store for expensive repair bills or worse having to scrap the car.
Engine wise look for the obvious, make sure the oil isnt black etc, if it is walk away straight away. Start it up, make sure that there isnt any blue smoke coming out the exhaust as this will indicate a blown TurboCharger and white smoke which indicates a Head Gasket failure. And check all the usual, suspension, electrics etc
F R O $ T Y
