Technical  Uno Indicator Relay
Uno Momento
Where does the indicator relay live on a mk1 uno? I've tried the fuse box but i can't find it!
behind the steering wheel, inside the cowling.
look underneath, undo 2 screws, small cross heads, need a medium length driver
remove the plastic covers, carefully, some delicate bits that cn snap off
under the wheel, to the left i think, is the little cube you want(y)
pulls out, in goes another
yours is knackered?
thanks for that jai
I've got a panda and the indicators on that aren't working. So i wanted to try the relay from the uno on the panda. Hopefully then i'll know if its definitely the relay or the actual indicator stalk
