Interesting points here...
Jai - thanks for the recommendation
As you said, the problem is in the low voltage to the bulbs. When these cars rolled out of the factory, the voltage was sufficient - but now, with old connectors and switches, they're just not up to scratch. Deal to that by fitting relays and you solve the problem at the source... where you go after that is up to the individual (illegal 100W bulbs, HID kits, etc. all unnecessary when you consider the improvement that the relays make.)
Jai - wonder if you've had the headlamps re-aligned yet after I did them 'roughly' :chin: Can makes all the difference to how useful the lights are...
HID kits. These have a number of problems. One is that the light source (usually long and thin) may not be the same shape as the H4 bulb filament. That means the HID light may not be aligned with the focal point of the original reflector (which was designed to suit an H4 bulb) and therefore, a good portion of the light is being thrown away - as dazzle for other drivers, and not helping your vision. There's a reason why auto-levelling is required for HID lights. And, all the OEM HID lights I've seen are used with lens optics (projector lamps) rather than reflector optics. There's a reason for that, too.
Another problem is that the intense blue light that everyone wants (because it looks soooo bright) may not illuminate certain signs, grass verges particularly well. Especially our roadsigns in NZ, which are yellow...
A final problem - dodgy high-voltage electronics. How well is that going to work - cranking the volts up into the thousands - if the source voltage isn't even 12V to start with? Current consumption could be high. I've used similar high-voltage inverters on cold-cathode fluorescent lights under my Uno (probably best not to ask
) and they've popped one-by-one. I wouldn't want to be depending on anything like those to see my way at night.
However, if you've shelled out on HIDs and feel they're worth it for the Uno, that's fine
Still not legal though! (Why take the chance?)
The second point Dunc raised about painted windows - presumably it's OK to paint the rear side and back windows, as that's basically like a van? In NZ there's only a restriction on front side windows and windscreens - which must allow 35% of the light through.
as i always point out, i'm never that fussed what you do with your cars gents, but....to be forewarned is to be forearmed, if you do get tugged, and your car checked over, and the offences found, and pointed out, you have deal with it, and crying later, as quite a few do in the LL, doesn't really cut it
That is so, so true. :worship: Again, why take the chance? There are so many more exciting things to chance in life...
-Alex
