General  Uno Fire starting problem
eoin
Hi all.
I have a 2005 Uno Fire 1.3 l. Recently have experienced intermitant starting problem. Over a two month period it has happened about six times. Always has happened on hot start. No battery problem. Starter motor turns over. Air filter clean. Usually after waiting 10 minutes it then starts. Any suggestions appreciated.
Initially, assuming it doesnt even attempt to start at all while you churn the starter, I`d suspect the ignition, either the amplifier or pick-up in the distributor, or coils if its the later coil on each plug type, or the wiring around them hardening & cracking.
