Unknown problem
Unknown problem
G
Gabriel
Hi guys
where it show km/mileage(187000km) start blink saying some kind of error but it not possible to see what was the error.
Anyone know what kind of errors it can be?
Bravo jtd cf3 2002
Try this....
1. turn to key to MAR
2. wait about 30 seconds
3. return the key to stop
4. Test this step as described below:-
a. Set the following configuration
- temperature knob on "HI"
- distribution knob on "MAX DEF"
- ventilation knob on "0"
b. turn the key from STOP to MAR
c. within 10 seconds, turn the ventilation knob through the following sequence:
"0" - "AUTO" - "0" - "AUTO" - "0"
sounds like a temp or aircon problem
you shoudl get an error code show up on the screen, write it down aand post back :)
Darren
makes all the sense! when the temp is cold makes heat and when i turn to heat makes cold.
I already done like you said and didnt show. I have being thinking and error appears after the car have being stoped at least 8 hours and i didnt turn no the ventilation and aircond. I only can read error miss some traces of digital and is impossible to read.
ok chap,
Normally when you do the process above it shows a error code on the screen and you can find out the problem.
I think one of the most comon problems with the temperature display is the outisde sensor under the mirror. Normally it's broken or the wire has come off.
If you can't see the screen though I am not sure how to find out.
Darren
A
1
6K
Dark Lurker
W
953
wakka
W
T
1
847
Joseph
J
O
3
599
K
V
5
785
Laurie
L
