Technical  Uniair module
Yorkshire
Hello all, my brains been sparking, occasionally on startup especially when its cold in the morning my panda has a bit of st vitus dance pretty much done this since i bought it, likely the uniair vvt it has right oil filter regular oil service blah blah, now its probably at some point going to pack up but until then i will let it make shapes on the dancefloor bit like its owner, now my question is i know that its controlled by to solenoids but do the lift just up and down on off or do they lift up and down in a variable fashion? Are they variable voltage to lift them at certain points? If anybody in fiat forum land could enlighten me it would be fantastic If anybody had a knackered one kicking about i would love to take one apart to see how it works, i've seen lots of stuff on you tube where people have cleaned them because they are gunked up with dirty oil and detritous, possibly you might be able to clean one up out off the engine in an ultrasonic cleaner while lifting the solenoid in various points, who makes the solenoids and the valve they operate the list goes on,
Had a look at this yesterday, seems they have multiple actuations which has me wondering do the solenoids lift up and down in various positions if so does different voltage control this, my experience of solenoids is they are either open or closed, i wonder that when they pack in they are not opening or closeing completely, love to put a knackered on a bench test and test with voltages to see if they are on a variable voltage but either i wait till my one packs in and fit a new one and butcher mine to find out or try and get a knackered one from somewhere to see if it is possible to clean and repair, ive seen youtube videos with different types of vvt solenoids where you can just clean the muck out of them
The document attached explains the solenoid drive requirements somewhat better, see page 11. My understanding is that the solenoids are a press fit into the Uniair casting and most probably impossible to remove.
  • Multi or twinair explained.pdf
Would be interesting to take one to bits to see how it all works on a bench even if i had to break it up to find out just my inquisitive mind on the go again sends my mrs round the twist😅
If you get this far hit me up and Ill come and watch. The VVT solenoid on the 1.2 is elctrically controlled. When they work you can tell it has more than 1 step in the process. Having had a good look at the thing its celarly black magic. As for the Uniair black magic doesnt come close. The Uniairfilter is not supposed to be touched. I am pretty sure this is because of the risk of introducing contamination while doing so which would be very easy. Cleaning it is clearly straight forward and probably would be good. But anyone doing so should be meticulos min ensuring nothing, not a single grain of road dust enters the system during cleaning the filter.
I bet you take it apart and then wont be able to put it back again. The story of my life.....
@Steveetee55 You have been asking about voltage.
https://kones.eu/ep/2017/vol24/no3/229-236_J_O_KONES_2017_NO_3_VOL._24_ISSN_1231-4005_RACEWICZ.pdf
The original control signal of the Fiat MultiAir system is the PWM voltage of about 12 V of
amplitude and about 31.65 kHz of frequency (Fig. 9). High frequency of the signal is due to the low resistance of the solenoids valves and though necessity of the current limitation and the power consumption reduction. The PWM factor is equal to about 18.5% what gives about 2.2 V of resulting DC voltage.
I asked ChatGPT 5.1 about this.
Convincing response:
Short version:
The MultiAir/UniAir solenoids are very low-resistance coils that are driven from 12 V with a high-frequency PWM carrier (~31.5 kHz), and the ECU shapes the coil current (not just the voltage) in a bias → peak → hold profile. On top of that, the ECU turns the whole PWM stream on and off at specific crank angles to get the required valve lift curve.
Below is how it all hangs together.
1. Electrical characteristics of the MultiAir solenoids​
Coil resistance and current
Workshop docs for the 1.4 MultiAir give a typical solenoid resistance of about 0.25–0.30 Ω.(forum.alfaholicy.org)
The Racewicz paper you’re quoting measured that each solenoid needs roughly 8 A of coil current to switch reliably.(kones.eu)
Because ( I = V/R ), a 0.25–0.30 Ω coil on a 12 V battery would try to pull 40–50 A if you just slammed 12 V DC across it, which would cook things very quickly. That’s why the ECU uses PWM and a current-controlled driver rather than a simple on/off 12 V feed.
2. The PWM carrier from the ECU​
From the oscilloscope captures in the Racewicz paper (the bit you quoted kones.eu)
  • Amplitude: ~12 V
  • Frequency: ~31.65 kHz
  • Duty cycle (average): ~18.5 %
  • Equivalent DC voltage: ~2.2 V (12 V × 0.185)
So electrically you can think of it as a 12 V square wave at 31.5 kHz, duty-cycled so that the average voltage seen by the coil is ~2–3 V, which is enough to get 8–10 A through a ~0.25–0.30 Ω winding once inductance and wiring are taken into account.
Why such a high frequency?
  • With such low coil resistance, high frequency + low duty lets them limit the average current to a sane value.
  • 30 kHz is well above the audible range, so the coil doesn’t “buzz”.
  • The coil inductance smooths the current, so at 30 kHz the current ripple is small and the ECU can treat it as essentially DC.
Racewicz’s external controller literally multiplies an “enable” signal by this constant 31.65 kHz carrier (logic gate), then feeds a MOSFET that sinks current from the solenoid.(kones.eu) That’s also effectively what the OEM ECU does internally.
3. Current profile: bias, peak, hold​
Fiat’s own eLearn documentation for the Magneti Marelli 8GMF (the MultiAir ECU) describes the solenoid drive as a special current profile with three phases).
  1. Bias phase
    • Average current ≈ 4 A
    • Keeps the solenoid “ready” and overcomes static friction / oil forces so response is fast when the main command comes.
  2. Peak phase
    • Current quickly ramped up to ≈ 11 A max
    • Ensures very fast armature movement so the hydraulic valve actually shifts within a fraction of a millisecond.
  3. Hold phase
    • Current reduced and held around 5 A
    • Enough to keep the solenoid in the commanded position without wasting power or overheating.
The 31.5 kHz PWM duty cycle is what the ECU varies to generate those three current levels. Internally it’s a current-controlled, peak-and-hold driver: it monitors coil current (there are specific DTCs for “UniAir electrovalve drive current feedback”).(forum.alfaholicy.org)
So, when you see “18.5 % duty = 2.2 V” in that paper, that’s basically the average drive during one of those current phases, not the whole story of what the ECU can do.
4. Timing within the engine cycle​
Now the more interesting part: when those solenoids are energized.
Mechanically, MultiAir works like this: a hydraulic piston follows the intake cam lobe and pushes oil into the valve actuator. A normally-open hydraulic solenoid controls whether that oil pressure is transmitted to the valve or dumped back to a small chamber.(Stellantis Media)
  • Solenoid closed (electrically energized): hydraulic path is “solid”; valve follows the cam (full mechanical lift).
  • Solenoid open (de-energised): pressure is vented; the valve decouples and closes under its spring.
So the ECU doesn’t “meter lift” directly. Instead, for each cam lobe pass (each intake event for that cylinder), it decides:
At what crank angle do I turn the solenoid on (close it)?
At what crank angle do I turn it off (open it again)?
These two angles define the valve profile, within the envelope of the mechanical cam.
Typical time scales​
Take the example in the Racewicz measurements: 1500 rpm.(kones.eu)
  • 1500 rpm crank → 25 rev/s → one crank rev ≈ 40 ms.
  • Camshaft runs at half speed → one cam rev ≈ 80 ms.
  • The intake event occupies maybe ~120° of cam rotation (≈240° crank), so ~25–30 ms of real time.
Within that ~25 ms window, the ECU will:
  1. Start the solenoid drive (bias → peak → hold) somewhere around the opening flank of the mechanical cam profile.
  2. Maintain or release it depending on the desired mode (full lift, early closing, late opening, multi-lift).
The actual PWM carrier at 31.5 kHz has a period of ~32 µs, so during one valve event (~25 ms) you have hundreds of PWM periods. The on/off “envelope” of those periods is what corresponds to the timing of the valve event.
5. How different valve modes map to solenoid timing​
Using the standard MultiAir modes (from Fiat/Schaeffler technical docs and training material kones.eu)
  1. Full Lift (high load, high rpm)
    • Solenoid is energized (closed) for the entire cam lobe event.
    • Hydraulic link is solid → valve follows cam fully.
  2. Early Intake Valve Closing – EIVC (part-load torque, low–mid rpm)
    • Solenoid starts closed, then the ECU de-energizes (opens) it before the cam lobe ends.
    • Oil is dumped early → valve closes earlier than the cam would, trapping a controlled air mass without throttle losses.
  3. Late Intake Valve Opening – LIVO (idle / very light load)
    • Solenoid is open at the start of the lobe, then the ECU energizes it later in the lift event.
    • Valve opens late and with lower effective lift, shortening the event and improving mixture speed at low load.
  4. Multi-lift (two smaller valve events in one cam lobe)
    • Solenoid is toggled closed → open → closed within a single cam event.
    • This gives two smaller valve openings, useful for emissions and combustion control in some operating points.
The oscilloscope plots in the paper you cited (Fig. 8a vs 8b) are exactly this: at the same engine speed, the solenoid “on” window is different for full-load vs minimal-load, changing when the intake valves open and shut even though the cam lobe itself is fixed.
6. Putting it all together​
So if you imagine the command to one MultiAir solenoid for a single intake stroke, electrically it looks like:
  1. Enable window(e.g. 10–25 ms long at 1500 rpm)
    • ECU decides start & end time based on crank angle, load, etc.
  2. Within that window: current profile
    • A short bias period (~4 A), then a peak (~11 A), then hold (~5 A) to keep the spool shifted.
  3. Carrier PWM
    • The whole thing is implemented as a 12 V, 31.5 kHz square wave whose duty cycle the ECU continuously adjusts to get the required coil current.(kones.eu)
Outside the enable window, the PWM duty goes to zero, the current decays, the electromagnetic solenoid de-energizes and its return spring opens the hydraulic path, and the valve is allowed to close under its spring force.
Thanks for this i will give a good read up tonight to me a solenoid is nothing really complicated if i can get a knackered unit i have the means at work to take it apart, i still think they play up because the the valve part of this solenoid get clogged up with muck possibly because of oil thats got thick and gunked up, i'm sure an ultrasonic cleaner with correct fluid in it would clean this up, if or and when my uniair decides its drawn its last breath i will buy and fit a new one anyway and see if i could have a fettle with the dodgy one
@Zardo Thanks for finding and posting that paper; if I have read correctly this describes the construction of an external controller for the Multiair head. They conclude that the device allows "...a possibility to test other inlet valves control procedures, which have not been yet investigated by Fiat manufacturer." The term "MultiAir" is used but the application is "TwinAir". It would be fascinating to know whether there are any subsequent publications?
I realise your point was to demonstrate operating voltages etc but the speed and response of those (essentially) servo-hydraulic valves is incredible and to know that they are available to the mass produced automotive market almost defies belief! Knowing how easy it is to hit the rev limiter in my TA makes my engineering sensibilities wince!! Poor little servos!
The data presented should also make people think harder about the sampling rate that MES tables present (0.5second??) as seen in recent posts and its relevance!
