mildred593
So I finally got on with removing the malfunctioning Blue and Me (B&M) module in the hope that it will fix the tedious battery drain thing.
Panda '63 plate TA 4x4
I can confirm that the unit is under the drivers seat...
Some pictures will be added;
Thank you for your explanations. Can you attach the pictures you had if you still have them? I have a Fiat Panda 2015 1.3D and surprisingly the blue&me module failed. I'd like to at least disconnect it to avoid any battery surprises and to repair the flashing odometer.
Under the driver seat, there is a plastic case, but under it I can only find two connectors which I believe are for the seatbelt sensor. right behind this I can sense under the floor fabric a small square unit. It seems small and I'm really not sure this is the blue&me unit. I would need to rip apart the floor fabric and I'd like to avoid it if necessary.
edit: I don't have a uconnect (autoradio with large screen)
Thank you.
