Hello,
I have a problem with the front dipper beams (lights) that are not working. I checked the fuse box in the engine space - there are two 15A fuses for both lights. There is the proper voltage on these fuses when I switch lights on. The color of both wires from the fuses is black. The color of the wires in the connector for the ligth itself is brown. The connection of the black and brown wire is broken somewhere now. Where is located the connection point of these two wires?
Thank you
Thank you
