Technical  tyre pressures
mackd0001
Jigsaw Couriers
Glasgow
Just wondered what everyone else had their tyre pressure at ?
most of the time my van is running fully loaded usually with a pallet of something in the back of it.
had a pallet the other week that was just under 600kg :eek: but the wee van still climbed hills no problem
Mrs_G's Cargo runs 40 psi front, 50 psi rear. The handbook clearly shows no change in pressure when empty/fully loaded. I assume this is because the Cargo should be fitted with 88T reinforced tyres.
Again on the passenger model it's 40psi at the front and 50psi at the back on maximum load. The passenger version does however state lower pressures for carrying less weight, although this is probably just for comfort reasons as my back end gets a bit bouncy when there's no weight there :)
