Hi
No direct figures..
But the concensus was its was still better to fit a mk1 puno 85 motor than a twinair85..
As 'similar' power AND WEIGHT
I lifted a FIRE motor myself 20 years ago.. so no way that was 100kg..
As you will be aware.. the Twinairs use 'weird tech' ..so driving them harder is pretty involved
What are your plans?
[FONT="]Cheers for that info, so is this the Fire engine you mean 1242cc 16V SMPI 80–86 PS (59–63 kW) (1998 – 2009)?[/FONT]
[FONT="]As you say similar to the 85bhp T/A – but the advantage of the 105 T/A is that when the turbo multiplication factor for hillclimbs is applied @ 1.4 it would still run in the up to 1400cc class if I wanted to do any events.[/FONT]
[FONT="]With a standard 105bhp and a six speed box, depending on the weight/dimensions, it would make a pretty good road car in something that originally weighed in at about 480kg = 219bhp/tonne [/FONT]
[FONT="]If the FIRE can be tuned that’s an option, but if it’s physically bigger as it’s a four pot with the transverse gearbox, the available space in the back of a Davrian could be a problem. [/FONT]
[FONT="]Even allowing for the weird tech, if the T/A can be tuned and the weight/size might be more compact, it might be able to be fitted into the engine bay of the Mk6 Davrian. [/FONT]
[FONT="]The Mk6 was originally made for an Imp engine/transaxle layout, but they did manage to squeeze a transverse mini into a few, but they usually fitted that transverse arrangement into the slightly wide track Mk7/8 Davrian’s.[/FONT]
[FONT="]If driving them (T/A’s) is harder, I would think for the road use it would still be easier than a 105bhp Imp engine, as that is really a track engine with a rev range of min 5.5K to 9K to get that power and would cost somewhere in the region of £8-10k these days. Which although is fun, isn’t that practical for the road. While 105bhp/sensible rev range could be fun in 480kg and should be more reliable(?) if it fits in the engine bay and the majority of the weight would be in the right place, i.e. like an X-19, but made of f/glass.[/FONT]
[FONT="]Davrian’s are better for putting odd engines in as the whole of the back end just unbolts, compared to a Clan Crusader, which I also have.[/FONT]
