Hi. Newbie to this forum.
I am trying to locate the turbo pressure sensor on my 2008 Ducato 2.3L 130 multijet which sits in my Hymer 654 Motorhome. Can anyone point me in the right direction? The reason is that i want to plug in a chip that will give me some more HP and save the engine and fuel on this +4000kg motorhome. The chip dealer says that MAP sensor and turbo pressure sensor is not the same. I have foubd the MAF sensor which is just after the airfilter on the right side of the engine when looking into the engine compartement. The tibe seems to go behind the engine along the inner wall and the comes up on the left side og the engine. The tube which is about Ø80-90mm ends up on the inlet manifold. Below the tube/pipe couple point i can see the EGR valve and the throttle butterfly is in the tube. There is a sensor just below the butterfly. Suspect this to be the MAP. It is a thight squess. Cant even see the turbo. Any pointers appresiated.
