Tuning turbo parts for 1.4 16v
kinross
hi folks need help to find few different parts for the turbo project.
im needing:
the small bolt like connector that joins the oil feed pipe to the oil filter housing where the feed is tapped from for the turbo, not sure if it will be the same thread type ect as the 1108 and 1242 8v maybe one of you could point me in the right direction.
oil feed pipe.
oil return pipe and fixing bolt pipe thing for sump connection.
cheers gregor
may sounds silly but are you doing a 1368 turbo 16v in a cento....
if so then your probably already using aftermarket ecu... and seen as there is one in the classifieds why dont you just sod it and go for a t-jet? reliable turbo power. (you will need a fire gearbox though probably a stilo 6speed.
