Seicento tryna get my seicento to spit fire
seicento boy spi
Ive been trying to get my seicento to spit flames for quite a while now and I seem to be having no luck anyone here got any ideas??
Spark plug in exhaust and a fuel supply but you will set it on fire
It only took me a few hours :slayer:
I've done this before, you'll need to get down the scrapyard and pick up a coil pack, an injector, a spark plug and a switch, plus a few odds and ends from ebay (a resistor and so on) I ran mine from a small alloy fuel tank I made up. You need to plumb the injector into the exhaust pipe 'upstream' of where you weld the spark plug bush. It took me a few attempts to get the right distance apart, so be prepared for some experimentation. I can't remember how I wired the injector but in sure it was a different voltage and I had to use a resistor or something. (Get the plug from the scrapyard injector too). Basically you run the fuel pump, fire the injector and the spark plug and it turns your exhaust pipe into a flamethrower.
Caveat: you need to spend a fair while experimenting with it and it is really rather dangerous. I made considerably larger flames than I'd anticipated and the potential for injury is huge. Also, I did this years ago and can't really remember much about what I got the parts from or which distances were critical. Don't let that stop you having a go though!
Get a 380 cargo engine, bigger pistons, water injections twin turbo with insanely high boost, massive bosch fuel pump, maybe run on ethanol aswell. Put it under an immense load, take the load off after 30 ish seconds, should spit some flames then.
