So I had to change the left hand side inner cv boot on my 02 sei (wet shaft gear box). I found that i needed to change the bearing too. Anyway, i've got the tripod off and removed the bearing. I've put the new bearing on the shaft but then I realised that I did not mark how the tripod was aligned on the shaft.
Is this a problem? Can i fit it anyway or should it align with the trip on the outer end?
I thing I might need to change the outer boot anyway so I inten on having that off so that I can see both tripods.
Thanks:worship:
Thanks:worship:
