General transmission/gear oil (Robtic)
BlackF
hello guys. maybe you know If Are gear oil and transmission is the same lubricant? Can I use like Torco RTF for both of them? Fiat bravo 6 gear robotic 1.4
198a4000
yes, normally they are the same, but, if you go onto the website of the oil producer, you can usually look up the make and model of the vehicle and it will tell you the recommended oil for engine and gearbox/differential for the Bravo. Being in Australia, I do not know that brand.
John
Update: so i put the oil and car run fine. for now is 3 weeks
I'm not sure what your original question was but
Gear oil and automatic transmission fluid are very different things.
Plus Manufacturers are starting to use the term manual transmission fluid.
Please don't mix them together or use either in the wrong systems.
Vitally important to put the correct fluid in the robot. And the gearbox.
