K kburton66 New member Joined Aug 3, 2015 Messages 1 Points 1 Aug 3, 2015 #1 Can a Fiat (manual or automatic) be flat towed behind an RV? Technically not legally. Last edited: Aug 3, 2015
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,900 Points 10,505 Location Near the M4 Aug 3, 2015 #2 kburton66 said: Can a Fiat (manual or automatic) be flat towed behind an RV? Technically not legally. Click to expand... Hi, on an "A-frame" the only normal concern is lubrication.., the normal stumbling block is with a full-AUTO gearbox, as it'll be spinning (from the road wheels) without the engine driven lubrication pump, however MOST modern FIAT's are actually a "Manual" gearbox, with an ECU controlled clutch + gearchange, do a little research - as I'm afraid your US spec. 500 is different from the EURO models, I hope that helps, Charlie - Oxford,UK
