gar074
Prominent member
Has anyone investigated fitting a towbar on a Cross? I imagine that it will probably involve cutting a hole in the skid plate, which would stand out like a sore thumb
Just seen a new 4x4 panda in Penistone with a toe bar on! It doesn't come through the bumper but from under the car on a swan neck ! So will fit the cross no problem!
The westfalia detachable is like that....
View attachment 152773View attachment 152774View attachment 152775View attachment 152776
I hope those help. I had just the same concerns on my 4x4 (non cross) but you can't see the cut. If you look at those photos you can see a normal view and a much lower view. If you zoom the lower view you can see the cut out. Plus I've done the rear shots. It is very neat and I don't think you'd be disappointed.
Is yours a Westfalia too, Philboo?
The guy that fitted mine also did it without drilling a single hole and just used existing grommets.
As I wouldn't need the electrical connection for my intended uses, is it a do-able DIY job to fit the bar itself?
I don't need the electrics, as the towbar is only for holding my bike rack, and towing the wheelie bin down the drive once a week on bin-days!![]()
