Torx bit
Torx bit
S
scottmetro
Has anyone got a torx bit/screwdriver for the Bravo MAF sensor i couldhave/borrow (i will return) just to get the screw off my MAF sensor to clean it.
alt does anyone know where i can get one quick, ive been to hellfrauds but they only come in kits aparently
only need it for a 5 min job
thanks
Scott
You can get them out by cutting a slot across the top with a hacksaw. dont cut all the way in, just enough to enable a good grip with a flat blade screwdriver.
If you want the tools, then go to your local market and pick them up for a £5er but beware, count the star points, as some are 5 star and some are 6 and dont forget they are security ones - i.e. have a hole in the middle!
i've got a kit if you are near dartford or try you local brown brothers or partco motor factors.
Maplins or similar sell kits with all the bits in, they're not expensive. Try your local motor factors, too.
A
2
889
Tommy K
T
K
9
551
Dark Lurker
P
392
paull
P
A
436
Ant Wells
A
