Technical torque settings
Mar4ix
Hi folks, my punto (1.2 16 v ) clutch bearing gone, and i decided to change clutch bearing and put new clutch. there was good bit wet with oil on dust plates, and decided change crankshaft oil seal.
all parts gathered, now have to instal.
just few questions, what is torque settings for that crankshaft seal plate, flywheel, clutch bolts.
thanks
hello there old buddy whats going on
Hi, thanks for that picture, helped a lot.
My punto clutch bearing gone... In bits. Just coultdnt pun in gear.
Took off gearbox, bearing just fell off in bits :(
However clutch and pressure plate looks like new. So, obviously previous owner probably was changing clutch in garage, where bastards didnt change bearing, left old one,.... Also pressure plate bolts wasnt in required tension, i just unscrewed by hand :(. Before bearing failed, symptoms was that it was hard to start moving in first gear, always had to overrew, othotherwise it would conck out, was thinking thats due bad timing, but now, after clutch change, car feels like new :) really love it. Changed crankshaft seal plate also.
Thanks for help.
