Intermittent problem for last 4 months.
Started as an issue if I tried to start car 3 minutes after turning off, (Shopping where you lock car) I would get a response like you get with a flat battery, that is starter tried to turn and light would dim. Wait for 2 minutes and everything back to normal.
Today I had the problem but this time from cold start. I think it could be to do with the central locking, and one of the motors is labouring and still being powered (nearside passenger door), there is no noise. I am going to remove door panel and inspect later, but if the motor was constantly powered wouldn't it burn out???
Also I have had the following problems in the past.
Battery light on dim for 5 years, I never found problem but it doesn't seem to cause any issues.
Blowing fuse when heater fan on highest setting. Cleared this by removing motor and cleaning gaps on commutator. (Carbon Brush Dust)
Jerking windscreen wipers. Cleared this by removing wiper assembly and cleaning the contacts that open when wipers are in the park position. They are in a plastic enclosure.
