tmendonca31
Hi all,
I own a fiat tipo 1.4 DGT from 1989 with a weber 32/34 TLDE carb. The car runs smoothly and with no fails when I press the throttle or when in idle. However, when the car is deaccelerating on low gears (2nd, 3rd) and the RPMs are below 2000, it tugs, like it had a lack of fuel. At that moment, if I give a little throttle or press the clutch, the problem is gone. According with haynes manual, I think that it might be an issue related with fuel cut-off valve or ECU, since the switching on/off occurs near the mentioned RPMS (1800). Have anyone else also experienced this before?
Thanks.
Thanks.
