Technical Tipo 1.4 ie dgt-1989g-ELECTRONIC PROBLEM digital Dashboard help!
CROTIPO1989
Tipo 1.4 ie dgt-1989g-ELECTRIC(ELECTRONIC) PROBLEMS-look this for yourself-and help!:
I am from CROATIA (Hrvatska) so please sorry for my bad english ,I would be happy if ther could be somneon for my promblems
from Croatia.
My Tipo (my dad's) is from 1989. and we have it for about 6 years .
It is model 1.4 dgt ie (benzine/petrol).
1.The first problem that we had was with electric
few months after buying in (2002/03),so the problem was in that the car in drive without
any reason started to shutdown the engine
(I repeate in driving,at high speed's, that was scary, imagine if you try to speed up
and another car comes from the other side and your car turns off!!! )
Nobody of mechanic and electrician in our smnall town could not
detect the real problem that appears occasional,all diagnostics
were in wrong ways the solution was in repleacing bad ''CAMSHAFT SENSOR CABLE''
(also called Crank Angle Sensor (CAS) or sometimes Crankshaft Position Sensor (CPS) )
the price in Croatia was around 70 EURO .
*The crank angle sensor tells the ECU the position of the crankshaft so it can work out when to fire the plugs and injectors.
Its usually either an inductive or hall effect sensor located on the flywheel or on a pulley at the other end of the crankshaft.
2.Another problem that we could not solve was ;why in our Tipo in winter the heating
is so low and needed much much more time for warm up the car inside,
after all this years we detected the problem in mass air flow indicator (MAF SENSOR called).
Now the heating is great and wery fast!
I readed that MAF can make a problems of slow work car engine,and wery high consumption of fuel.
3.And at last of thes big problems is unsolved until thes days.
The problem start to appear and disappear on the digital dasfboard,
the digital numbers of sensors and indicators for kilometre (kmh) fuel, rpm ,temperature,clock...
nothing of this does not working .
Electrician could not solve the problem ,nor say is the problem in dashboard or in car ECU
or some wires or something other.
There are 3 buttons on left side of dash that are for:LIGHTING ,TRIP,TOTAL TRIP
and when you press the TRIP and TOTAL TRIP together the all indicators on the dash ar lighting for check,
now that doesnt working to.
I just want to know where can be the true reason,is that in ;
1.DASH
2.ECU (car computer)
3.wire
4.something other ???????????????????
So if enybody know what could be the problem ,please help !
Driving now is wery dangerous ,HELP with suggestion's ,in any way !!
Another thing that I wolud like that all members of forum an you owners of Tipo's try to help is
to see what are this parts on my car,and where are they positioned and what is the role of them on car !!so look this pictures and write what do you know about parts,for what are they !so look this pictures and write what do you know about parts,for what are they !
the thing you've circled which is to the left of the battery and under the ignition module thing. is the thermostat.
Thank's Besbie this is now something ,you on fiat forum are realy fast
Others join please I am still interested what are the other parts on above pictures:worship: (y)
The "Digiplex 2" box in the engine compartment is ignition management module. It is used to set advance according to engine load and it also controls ignition coil.
The "Bosch" box under the dashboard is ECU, also incorrectly called "computer". It is responsible for managing Bosch Mono Jetronic injection system. It receives various data about the engine status (engine temperature, incoming air temperature, throttle position etc.) and adjusts the amount of the fuel injected accordingly.
I must say,it is unbelievable how fast are members on this forum to help
or just discuss about things and questions that I posted
,thanks Rampage94 and (CZ)enda !!!
All pictures that I posted are with intention to get conclusion what is
the role of each part in car and could it be the reason in some of them with problems that I had .?
So I wan't to get conclusion wher is the real malfunction of my not working DASHBOARD ???
Could it real error be in dashboard electronic system (chip's and other part's inside) or
the problem is in some other car unit that have connection with dash?
And here I am again,so the problem is now solved,after all the mehanics
said that the problem is certainly in dash ,we simply went on the old
cars landfill and we agreed with the owner of crashed Tipo for a cheap
price ( of 35 EURO) ,and now everybody happy,dash working for now !!!
The good thing is that the old kilometers went gone with the old DASH and
now we have with new one less than before !!
Thanks everybody, once again we successfully solved Tipo electronic problem !
