Trying to replace the timing belt but there seem to be two choices of size 15mm or 22mm. So how to find out without removing the cover and have a look.
What I seen there are 2 options available for the car both supposed to use 129 teeth but one is 15mm and the other one is 22mm. I ordered a 22mm belt only anyway. I know 15mm is used on my mk1 with less teeth count. So I suppose mk2 uses 15mm with more teeth but same length (just finer teeth size size to allow for more acurate adjusting), while mk2b hopefully uses the 22mm one. I know the 16V also uses 22mm belt size but different count of teeth.
