- Joined
- Nov 28, 2010
- Messages
- 28
- Points
- 10
Well heres the second in what will probably be a flood of questions
I don't know when the timing belt was last changed, certainly not in the last 3 years so I'm planning on doing this relatively soon. I will be doing the belt, tensioners and water pump. Is there anything else I should do at the same time? I've seen the auxiliary belt mentioned, is this essential or only if it looks worn? Should the tensioner or guide pulley for the aux belt be done at the same time?
