This has nothing to do with coolant hoses, just the boost hoses on the mjet.
If your losing coolant I highly doubt a new clip will sort
Wishful thinking on my part
Hi guys, is this also a common fault on the t-jet? When i'm putting my foot down i'm hearing a loud "sucking" noise. Is the turbo piping on a t-jet the same as on a m-jet?
This is diesel only.
ok, so what could be the problem on an t-jet?
This kind of info I can't provide, do what I did:
Remove hoses you want to upgrade,
Get a micrometer
Measure internal and external dimensions
Trawl eBay for hoses matching your measurements
If none, there's your answer
As for being sane as 1.3 or tjet? I don't know I have a 1.9...
I've just changed the 90 degree bend pipe and still getting the same leak noise, so I'm assuming its "item 1" on the diagram, anyone know where I can get it not off fiat preferably?
A whistle isn't how id describe it. More of a screech, like if you let a balloon down whilst pulling the ends.
Ta
Did you find out that this noise was?
I lost a small nut from the cold inlet on my turbo, it looks like it has been sucked through the impellers and I think it's in the intercooler causing the noise!
item 2 is the pipe this thread is about
item 3 is the j shaped pipe i referred too
item 4 is hard plastic
item 1 the long part is metal
Don't suppose anyone knows the measurements for the small silicone hose connecting the intercooler and metal hose (item 1) do they? Mine has just gone and I haven't taken it off yet.
If i remember correctly fiat have changed the whole set up due to them knowing its a failure think there is a new boost hose and a new metal pipe to buy cost me £130 i think, was awhile ago now though
