General The beast lives
There is no real change to the engineering, instead of two 10mm bolts, one from either end, there is one right through the middle. I could leave the mount a wee bit slack allowing some movement, but I intend to do the same to the third one and have the engine mounted just about solid.
Don't mention NVH!!
Cheers
Man, it's already brutal enough, this is a fullstripped fire spitting beastie!
Fun to drive but would nip your heid over long straight distances.
No offence intended!
Liam
I can confirm that the oil leak is sorted, and after a 'sprited' drive home tonight that the mount is still intact.
Full beam seems to be on part time working as does an indicator, so I'm off out to the driveway to investigate.
Cheers
There was one driver missing from the previous pictures. So to prove that the boy Liam was indeed present, and to stop Mrs Liam getting suspicious, here he is, on the door handles.
Cheers
