It could be that there is an electrical issue affecting 1 and 4. Injector failure is rare, two injectors going down is almost unheard of.
Update. Injectors were fine, the problem was that they were not getting information to trigger (negative pulse). Looks like the computer is so "smart" that when the spark plug isn't getting its information to spark, the same happens to injector.
New HT leads are arcing... Manufacturer is BREMI, problem was solved by a bit of insulating tape around them, but its just a temporary fix. Going to get better quality leads, and maybe even new coils.
Damn car ...![]()
Hi I have been following your post and I too same probs done same things to rectify but not made any difference. I am interested to know how you went about getting ecu and cost thanksECU was gone. My ECU wasn't right one for repairing, so got a renewed one and car works perfectly.
On Fiat 1.2 its saysI have an intermittent problem on 3 cylinder, coil pack. Today got the coil pack out and tried testing it with multimeter for resistance. Tried continuity and resistance but none of the number had any sence.
So I'm asking where to probe the coil pack to check for resistance.
Car is punto 1.2 8v, 2001.
Thank you.
For the Fiat 1.2 engine (code 178E2000), the typical resistance values for a healthy ignition coil should be around 0.4 to 2 ohms for the primary winding and 6,000 to 10,000 ohms (6 to 10 kOhms) for the secondary winding.I have an intermittent problem on 3 cylinder, coil pack. Today got the coil pack out and tried testing it with multimeter for resistance. Tried continuity and resistance but none of the number had any sence.
Thank you.
This thread is from 2014!For the Fiat 1.2 engine (code 178E2000), the typical resistance values for a healthy ignition coil should be around 0.4 to 2 ohms for the primary winding and 6,000 to 10,000 ohms (6 to 10 kOhms) for the secondary winding.
