As the title says, i am having some problems finding out where the temperatur sensor is located on my car.
It's from 1996 , its a 1.4 SX model.
The main problem is , the car is swallowing more gas than it should, so its either the lambda probe or the temp. sensor, ill start with the cheapest one first, since also inside on the dash board even though i know the car is warm and heat is comming in, the temp. meter doesn't move above C which basicly is a couple of centimeters above the point when the car is turned off.
Fiat Brava 1.4 SX from 1996
Motor code/type : 182A3.000
