General temp. gauge
General temp. gauge
eric 83
leeds
hello,the temp.gauge on my 1992 2.5td mhome went to 130 degs.when started it,engine was cold! so thought it must be the sender, changed it(HAVE TO REMOVE TOP ENGINE MOUNT)and checked contacts,still the same any ideas? thanks.
Hi, I have had a similar situation with the temp gauge on my 2003 2.8 JTD campervan. I changed the sensor too but it had no effect, (the temp still showed 'normal' when starting a cold engine) but after doing a search on the motorhomefacts.com forum I found that someone suggested disconnecting the cable/plug at the gauge end and it has worked.
I hope that this will work for you if you still have the problem.
Colin
:) fixed it!! found problem was in the vinyl circuit on the back of the instrument panel, changed it and everything ok ***tard thing.
