Technical  TD125 clutch
cutthroat jake
I know this is a stupid post but, does the Marea TD125 have an hydraulic clutch? Mine's buggered, basically, and it's failed like it's hydraulic, but I can't see any obvious signs of a reservoir. Thanks
CTJ
Yes it is hydraulic and shares the brake fluid resevoir so it's important to keep an eye on the fluid level. The slave cylinder can be found on top of the gearbox which is directly below the battery. You may find that the slave cylinder has failed which will be evident by a wet patch around it. It's not an uncommon problem. Had to change mine a couple of years ago for this very reason. It only cost about £20 from Shop4Parts and was a 30 minute job at most. I removed the battery and battery tray to provide easy access.
Good luck.
