Ok, so its been more than 2 years since I got "Lucia", my first car at 26. Over that time I have added my ICE as I got the cash and added bits of deadening and cabling as I went (and 2 new headunits, and 3 sets of speakers). I have decided that now I have got the time to re-do things so its all to a standard I am happy with - keeping the same equipment but improving the install (so not going to be anywhere near Paulbfd's Panda standard then). This thread is like my "blog" on the project, but all comments and suggestions are welcome. Pics are from my i-phone so prob not the highest quality. So, on with the project!
First some background info:
Car: Fiat Panda 1.1 Active, 2006
ICE Equipment at start of project:
Headunit: Alpine 9880
Front Speakers: Alpine SPS-171A Components
Rear Speakers: Alpine SXE-1725 Coaxials
Subwoofer: Vibe SQ8-Evo
Amplifier: Alpine MRP-T222 2x 50w RMS
Interconnects: Cheap RCA "unbranded" from 10 Awg and 8 Awg ebay wiring kits
Speaker mounts: Self made mdf baffles
Power cabling: 8Awg and 10 Awg ebay wiring kit stuff. Autoleads mini distribution block.
Speaker cable: A mix of stock speaker cable (which isnt too bad), the 22awg cable that came with Pioneer TS-1301i speakers, and allegedly 20awg OFC cable from ebay wiring ket (though I'm not convinced).
Deadening: Front 2 doors deadened with a mixture of dynamat extreme and silent coat 2mm and sealed with silent coat 2mm and yoga mat closed cell foam
Sound Isolation: b&q floor insulation in door cards.
Battery: Original 202 size 40 Amp 200CCA exide nearing the end of its life (just off the charger for the second time in a few months - alternator checked and working fine).
Battery positive: Original fit Fiat, past its best as loose on top of terminal and will not tighten
The plan
Front baffles: Redesign as mid-bass limited (I have some ideas on this to test)
Interconnects: Vibe FlatBass RCA Solid Core Interconnect to Alpine Amp, the better quality generic RCA to subwoofer
Speaker Cable: Stock cable from rear of HU to doors, Connects2 16 Awg frm amp to rear of HU and from door grommet to crossover and speakers.
Deadening: deaden and seal rear doors.
Power cable: Replace all 10 Awg cable with 8awg. Vibe Flatlines cable to be used for this.
Battery: Bosch S4 202 Battery, 42Ah 360CCA Maintenance free
Battery positive: Phonocar postitve battery clamp
So, is it worth replacing the existing generic 8awg cable from battery with the 8awg Flatlines stuff, or even 4awg (system only draws a max 50 amps going by the fuses on back of amps)?
The plan
