paula.harris
Hi I have been given a cinquecento sx 1995. it is beginning to sound like a tamk, is this likely to be the tappets. please help.[?]
rallycinq said:The tappets that are making the noise are jammed shut, the oil is unable to get into them, either cos they themselves are gummed up, or the oil feed to them is blocked. Derv, which is just 'oil lite' with detergents maintains the lubrication system but cleans out any oil residues. It is not completely foolproof. If the engine is completely gummed up, then nothing will really shift it short of taking it to bits, but for the sake of a few quid its worth a try.
Make sure you don't rev the engine when using the Derv, it will break up and you will loose the oil film from your shell bearings (this is not good) a fast idle is all it needs.
Hope this clears some of the mist
Grumpy old git going fast downhill rather than downhill fast!!
