alextjet120
- Joined
- Feb 1, 2017
- Messages
- 52
- Points
- 17
HI guys, right so im looking at taking the t-jet punto above 200hp.
my plans are as follows:
-upgraded intercooler (already have just needs fitting)
-forge dump valve (on its way)
-vxr corsa injectors
-1.4 16v n/a cams
td04 turbo- not sure if theres a specific type/ model you need
-downpipe/ manifold adapter to match
-free flowing exhaust of some description
-any sensors that need changing for it to work/ be driveable
-custom remap
now my questions are, will any of these on the list mess up the function of the car before the map, ie. the cams without being mapped in straight away?
can i run the standard clutch or will something go bang?
are the 380cc injectors a straight fit, can you just swap them in for more fuel with no problems?
other good ideas to keep the car running nicely.
cheers guys
-1.4 16v n/a cams
-custom remap
cheers guys
