General  T Jet Engine cover
motionlines
Hi! Any idea what a hole next to the cap is for? Is this to hold the cover tight?
The bolt on the top is probably for the hole, but I can't screw it in as it seems to be too short. Plz advise
Yes it is for a bolt, yes that bolt is to short.
I would check the hole is clear.. (no snapped bolt stuck in the hole).
The engine cover has another bolt on the right side. They should be the same size, so if that is the correct one, you can use that to check the hole and get a replacement.
