OK, for those who don't know, I have bought some of the parts from Dave the Trike's supercharger kit that he had running on his 1.2 16v Punto. I have read his threads and will be pinching some of his ideas (eternal thanks to Dave, he put blood, sweat and tears into that thing so I totally appreciate how easy I have it to be able to follow on from his work :worship
to get this up and running on my Brava, which has the same engine. I'm putting the thread here because it seems to involve parts from varying Fiats and some generic ones too. I have a friend, Ste, helping me this end, Jordan has also offered his occasional services (fitting in around his own project work, which he has enough of already, poor lad
) and I am aiming to really learn and have a good go.
So having done some initial research..........
Things that will have to change:
ECU - I am really interested in tinkering with this myself and have done a lot of reading about it. I can't afford and would be bored with the expensive, ready-set-up route so am considering Megasquirt (harder, longer, more interesting) or Greddy piggyback (still self-tune but less wiring-up required, less probability of making a mess but is it less flexible?).
Injectors - think Dave used the ones from the 1.8 and they swapped in OK.
Head gasket - something Dave had a problem with, need to look for a strengthened one, not yet researched
Add in an oil cooler of some kind - not yet reserached
Better air intake - think Dave used one from an old Escort to this could be an option.
Things that will stay the same to start but will change as we go along because the original parts most likely won't be good enough:
Fuel pump? Not yet researched
Cool running thermostat?
Brakes - open to ideas but I think a rear disk conversion is coming
Clutch assembly - something robust for the added but not too heavy - open to ideas
Gearbox - open to ideas, no idea yet what will fit
Will the driveshaft stand up to the incresed torque?
Other stuff to consider:
Mounting the thing
Tubing
That's where we are, still at the bottom of a steep learning curve! And once again, massive respect goes to those who have pioneered in this field, I have been reading through the threads in the Cinq and Punto sections and :worship:
Mounting the thing
Tubing
