General  sun visor
General  sun visor
Sun visor
. . . but can't see what keeps it in place, any ideas welcome . . .
Do you mean at the pivoting end?
The end of the plastic rod (where it extends through the mounting bracket), is heat-formed so it can't pull out of the mounting, I suspect yours has broken off.
You could drill a small hole in the centre of the end of what's left (as long as it's flush, or nearly, the top of the mounting block), then fit a small washer and self-tapping screw.
Basically you need something that'll stop it pulling out again.
Edit; Can you post a picture?
Re: Sun visor
thanks bike doc it worked a treat. I took the bracket off and there is already a hole there, so i pushed the visor back into its mounting and secured with a 3/4" x 10 pan head self tapping screw... good as gold solid as a rock... thanks very much for that tip
