- Joined
- Aug 15, 2013
- Messages
- 457
- Points
- 165
Hi guys,
So.....My MK2b has had an oil leak ever since I've had it (18 months or so) I thought I'd fixed them by changing the rocker gasket the split oil breather pipe and coil 'o' ring but it looks like the sump has been the biggest culprit all along
I had a good look around the car and the top is all clean, zero oil anywhere above the driveshafts.
Underneath is a different matter, it looks like she had a new sump and drain plug in the near past, is it worth removing the sump and putting a new gasket (or is it just sealant?) on or is it a case of, you've got the old one on, you may as well bung a new one on?
Here are some pics, hopefully it'll confirm it's the sump and not something more sinister!
Clutch side
Cambelt side:
Clutch side
Cambelt side:
