edbremner
Hi Guys,
Wonder if you could help diagnose my Cinqy clutch/gearbox problems in any way.
Recently I changed the clutch on my Cinqy and it has been in and working for 3 or 4 months and most probably done about the same thousand miles. It has been adjusted, settled down and as far as I was concerned was a job done and dusted.
Yesterday, I was coming down a very steep hill (Porlock Hill, in case anyone knows it) and as the car was heavy and full to brim, was running in a lower gear than I would feel normally right, for the engine breaking, but in no way hard revving at all.
I went to change gear and the clutch felt fine, if a little heavier than normal, but it was really hard to get it into any new gear.
I stopped to find that although the clutch felt fine, I was totally unable to get it into any gear at all.
When I was rescued, the guy jumped in, tried it and said the clutch seemed fine but that the gear selectors had jumped or were not working. I have since checked in case it was as simple as the mushroom joints jumping off, but no luck, not that simple and the gear selectors seem fine.
So to be clear.
The clutch feels fine, if possibly a little stiffer than it was, the cable is not broken and is moving the clutch release mechanism, and all looks fine from the outside of the clutch housing.
The gear lever, when engine is not running, can select gears 1-3 with ease, and 4,5 and reverse with a little jiggling. The gear lever is moving the selector on the outside of the gearbox and there does not seem to be any problems that I can see at all - at least externally.
When the engine is running, and the clutch fully down, you simply can not push it or even force it into any gear at all.
The clutch feels fine, if possibly a little stiffer than it was.....the gearbox feels fine when engine not running.
It feels like the clutch plates are just jammed together and not separating. Is this possible? I have never had a problem like this before.
What are your thoughts? Any ideas? What are my next steps in diagnosis or fixing this.
cheers
eib
So to be clear.
cheers
eib
