Ok boys and girls, seems you all need a very basic lesson in suspension and terminology..
(Thanks to wiki for the pics)
Toe angle is commonly referred to as the "tracking"- whether the wheels point inwards or outwards at the front edge.
Camber is whether the top of the wheels are tipped inwards or out (think of an F1 car).
Nearside is the side nearest the kerb (passenger/ left-hand side)
Offside is the Driver's (right-hand) side.
beany_bot- The suspension angles should be the same both sides, if one side is
cambered more than the other- you've got an issue (bent axle/collapsing wheel bearing/etc).
Most tyre fitting bays can do a full 4-wheel alignment check and provide a printout which you can show the Dealer if it's a warrantable fault.
