Punto (Mk2/2b) Storing radio codes
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
gingerwhinger
Recently bought a Punto for the wife to run around in. I found the radio in the boot. When i fitted it i got the "code" message. Went online got a code and was able to enter it, but how do i store it? The web site said after inputting the code press pre set 1 then 3. This dont work i just get a wait message. Help
Ginger
wait usually means code not accepted and so you need to leave radio on to clear the lock down
theres a procedure but i have forrgotten it. maybe google can help again here
are you sure radio is compatable with spec of your car because not all factory radios work in all models and may be the reason radio was in boot
No i,m not sure if they are compatable. Just assumed it was the correct radio for the car. All wireing was correct,,and its a Fiat / Philips radio. Got the code from a site using I D numbers printed on the radio label and indented in the radio itself. Maybe its just not the correct code. Thanks anyway.
Get a Blaupunkt stereo from a scrappy or ebay and use that code and you should be all set.
we do punto bluespot radio codes on here for a donation to the forum to keep the wheels on
so you could buy a cheap one from ebay codeless and get the code here
remember as i said earlier though if you car is say a mia then a punto high cd player will not work in your car so either ask on here and we will try to guide you or ask the seller
