Technical stilo reverse lights
Nottingham
Ok so bit of a strange onre, all my lights work apart from.my reverse lights, bulbs are fine but when I select R I get no lights at the rear of the car, is there a fuse somewhere for them????
it wold be better if you posted in the stilo world mate :p
theres a reverse switch on the rear of the Gear box , Go in from the pass side , you will need a 19 mm spanner and you can remove it , and replace it ,,
mines the same i have to rev lights , take the sensor out and press the switch and they work , put it in the box and they dont so , the sensor must be worn a little ..
