Technical  Stilo JTD power loss
push both the bottom sides in and it should come out either to the left or right.
as in the two screws you need a star allen key with a hole in the middle of it. not sure on the size off the top of my head.
pull it out slowly, but you may have to twist it a little to get it out.
after it is out, you will see a metal contact on the bottom and inside the square thing ( you will know what i mean when you see it)
spray it all with electrical cleaner until it is clean and leave to dry.
then put it back how it was, plus it only goes back in one way. so make sure you remember what way you pull it out
DO NOT USE A CLOTH OR COTTON BUDDS OR ANYTHING TO CLEAN IT. JUST THE SPRAY.
i found out the hard way and had to buy a new one haha
hope that helps.
clean the map sensor also to help in mpg
