Technical  Stilo JTD cutting out
edwin884
Searched the forum and no help....
So. I have a Stilo, and recently weird things started to happen.
It's a 2004, 59kW, 3 door JTD.
It cuts out the engine while driving, but only when the clutch and the brake pedals are depressed.
WTF is happening?
Hi. Try just depressing the clutch without braking, does it still cut out?
lots to check. Try checking the idle control valve, clean it if its dirty.
The control valve is at the end of the inlet manifold, your plastic induction pipe goes to it and there is a valve on the side that controls the flap between the plastic pipe and the aluminium inlet manifold, they get clogged with carbon you will need to remove the 3 bolts and two torque screws holding the control valve that is connected to a pipe and using a flat blade screw driver unclip the plastic cup off the ball, also you have to remove two allen key bolts for the EGR valve that is attached by the way of the 90 degree steel pipe, the flap inside the housing should be nice and free. Also check EGR not clogged with Carbon, That is a bit tricky to remove due to pipe underneath it. also check the pipe going to the little control valve you remove to ensure its not broken or has a hole init. Hope that helps ? it is not that bad to do, the EGR is connected to the control housing and has a black solenoid with the plug on the end and that gets badly carboned up and sticks as well, look on you tube it shows you what it looks like and cleaning it with brake cleaner and WD 40 plus wear rubber gloves as it takes weeks to get the carbon off your hands.
The JTD engine does not have an Idle Control Valve. Idle speed is controlled electronically by the Engine Mangement ECU depentant on the input of various sensors.
The buttterfly valve on the end of the inlet manifold is an anti shudder valve. It only has two states, i.e. fully open when the engine is running or fully closed when the ignition is switched off. It's sole purpose is to prevent air inlet as the engine is switched off to avoid engine shudder.
I feel it's gonna be the fuel pressure sensor.
The car is actualy my wifes, and she called me and said it switched off during driving. Now the engine fault came up, but now the car runs fine!?!? It's gonna be checked tomorrow!
I have unpluged that pipe that goes on anti shudder valve because of the oil or black stuff leaking there and i was afraid it will goes on vakum box, but now i dont know if i should close that pipe with a nail ore leave it without closing it, sorry for my bad english
May be totally wrong, but I had a Vauxhall Combo (Fiat Doblo clone) that died as you dipped the clutch and pressed the brake pedal, it was the clutch pedal sensor. I see your vehicle has one, but it is a different design.
Incidentally with that fault it showed on good diagnostics as clutch pedal sensor error code.
