Technical Stilo abarth selespeed clutch/flywheel parts
baykah
Hello,
After reading a lot on the forum for my abarth (91 000km), I starting to think that I need to replace my clutch.
I'm in France, I have fiat ecu scan, I know pretty well the selespeed after a lot of reading and playing with it and I have a diy garage nearby, with a mechanics that I trust !
I'd just want to get the good parts and all of them ... I don't plan on doing it multiple times ..
=> Selespeed tutela CS oil (2 litter in case)
=> EV0 (I have regulary obd overcurrent on this one)
=> Clutch replacement ?
=> Flywheel ?
=> Bearing ?
=> Main cylinder ?
And where to get those (cheap if possible ..)
Thanks in advance for helping me ..
I was planning to take parts from shop4parts
Clutch kit :
Selespeed oil :
Accumulator !
Maybe I should do a gearbox oil change ..
Slave / master cylinder for selespeed ? where ?
If my understanding is correct the gearbox etc is the same, the difference being it has a hydraulic actuator - which makes up the selespeed - instead of a normal gear shift. So clutches etc should be easily sourced. Check ePer to confirm that part numbers are the same which will tell you for certain.
