- Joined
- Jun 25, 2007
- Messages
- 2,789
- Points
- 437
It will be similar to the GPS Mjet boost, i think it runs around 1 bar post remap.
Why look for grief when you don't need toNo the stilo electronic won't have a hissey fit, just have your remapper make a change in your ecu when he remap it.
The OP has already proven the point with his first post
Time for you to start making some intelligible posts - unless you'd like your visit to this Forum to be rather short.No that was just talk from a man who didn't kown the answer, just as you.
How come it is so hard to get a stright answer here ? :bang:
Q= After remap
Whats that dip around 1,800 RPM haven't seen that before...
think i may have found out why there is a dip there now.
in 4th and 5th going from about 1500 rpm to 2000rpm there was a slight vibration
fitted EGR swirl gasket today, had a run in it and now no vibration.
its going on the rollers at the yorkshire rolling road day and we'll see what the graph looks like then
just got to wait for a map tweak for my GSR kit now
71751469 is the swirly gasket, 12 quid (ish)
you'll also need two 46773082 (£1.80) for either side of the swirl gasket, may as welll get 4 and replace the whole lot seen as youll be taking the EGR of to clean it anyway.
I gave you after remap, post means after doesn't it I dont understand what changing MAP sensor would do anyway. The Stilo has fairly delicate electronics, its not the same as a the 120 CDTI Vectra in this way. Ask people who have tried to remove the MAP sensor by adding an induction kit.... the car goes into "limp home mode"
Oh, but the 120 CDTI is an M88 from fiat power train aka 1.9L 8v 2.gen common rail engine aka Alfa 1.9L 8v Mjet and Fiat 1.9L 8v Multijet.
I did not write remove, but replace !
Replace the 2.5bar map sensor with an 3.0bar one and get a remap an ajust ecu to use the new 3.0 bar sensor.
This allow for more then 1,5(5) bar boost to be controlled by ecu.
There i alot info from Opel owner's that run 1.65 bar on the there 1.9 8V and Gt1749V turbo's.
:chin:
because quite simply i gave you my answer in the post i previously made,
i cannot afford it and i do not want to bring on any uneccessary agro by causing faults when i have got a a greatly improved gain from the remap as is.
do you not think 54BHP is not enough over standard?
or are you just seriously mentally retarded enough to want to destroy every car you own?
if the latter STFU and GTFO
end off!
Ive just read this thread and I am confused with the 54bhp gain as to where you got that from. Looking at the figures f/wheel before 137 after174 = 37 and wheels before 112 after 144 = 32. The 112 before is a bit under the 120 it should be I wonder if this sort of thing is normal, the reason I mention this is I have a 150 mjet or it might not be what ever the case is dosent seem to be on a par with my Marea which is mapped to 142bhp.
Do you get the SWIRL gasket from Fiat or is the somewhere to get them online?
Cheers.
