both driving graphs give the after cat minimum threshold of 0.000v...
http://ngkntk.co.uk/wp-content/uploads/2011/03/Lambdacat2011.pdfNTK Lambda Catalog said:As the sensor only functions correctly once it has reached approximately 300°C it is essential that the vehicle is brought up to normal working temperature before checking the readings. Once the engine and sensor have reached normal working temperature raise the engine speed to around 2000 rev/min, this should produce a fluctuation in voltage from approximately 0.2 volt to 0.8 volt as the sensor switches from fuel lean to fuel rich. This switching should occur in approximately 300 milliseconds. The next part of the cycle (fuel rich to fuel lean) should have a similar reaction time. Deviation from these figures will require the sensor to be renewed; a slow switching time is a fault that many Lambda diagnostic tools are incapable of measuring.
richydraper said:... if the mixture 'leans out' on acceleration the lambdas detect more oxygen in the exhaust and send a signal to the ecu. the ecu then ups the fuel delivery until the correct fueling is achieved.
inversely upon deceleration the lambdas would detect less oxygen and send a 'rich' signal to the ecu telling it to dial back the fuel delivery (possibly to the point of injector shut off)...
im having difficulty finding any supporting documentation that suggests 0.0v is an 'acceptable' level to recieve from a lambda under any conditions as you have suggested ivand do you have anything available that you could post? im interested to know what conditions i should be considering if i get 0.0v trace on any lambda i may test in the future!
Took some time this afternoon playing with MES, and checked aftercat signal on various rpms...it never dropped under 0.097V... Also I've noticed that aftercat seems to be always in open loop until engine reaches about 2000 rpms...
Anyway, here is graph...
Uploaded with ImageShack.us
least your sensor is goodthat makes one out of three!
Hi, how did you solve the problem, because I have the same problemThanks Richy for the absolute clarifications on lambdas.
I now understand that Open and Closed loop only means that the ECU is taking it into account or not, thou in the back the lambda is still providing a signal (which is what I see from the FES graphs).
Now my task is to have the lambdas checked out, I don't think they were ever taken out, probably they should be inspected at least visually besides measuring their signal with an oscilloscope before.
I read about clogged up cat's as well that can be "simply" taken off and cleaned (well, after some major elbow grease), to improve the drive-ability and the cars responses also fuel economy and hesitation.
How ever I look at it the Intake valve, Catalyst and Pre and Post lambdas have to undergo a check up.
As my finances let it I will do that, probably after Christmas ( my wife would be pissed as hell if I spend money now on the car and not on presents, nor is this what I'd like to do
) . There are several shops, garages and professional mechanics around town, I'll ask around from friends and try to find a good one that do professional electronics and diagnostics.
Still this bugs me so much I want to have it fixed, I like the little Stilo of ours, it's our first ever caryea she's 10 year old but she was taken care of and maybe all is needed is a new lambda (they do break down after a certain mileage)... if anything comes up I'll let you know for sure. Oh oh oh ... Important bit of information, we bought the car with some 98 000 km in it in February 2012, I honestly think the km have been tampered with (the FES even says revwrites 2 times - of course theres no date) and this is what my mechanic said as well, that the car does seem sound and in good condition but he personally thinks it has more than 98k km. We drove in it 13 000 km so far and she never died on us. Just this one more thing with the lambdas and car and I'll be a happy car owner
Z
