zoli
Hi to all reading this, I need you sincere help and advise!
My Stilo 1.6 petrol with LPG system installed has some issues with idle and low RPM up until to 1500 range. Not so much of a ruff idle but a strange behavior, let me explain.
I own a Stilo 1.6 petrol, year 2002, 5 door sedan. We bought the car second hand from a dealer this year in February, we drive it since but from a month or so ago with a little behavioral problem with low and idle RPM. We installed an LPG Landi Renzo system into the car immediately as we bought it, the job was done easily and professionally, no troubles with it what so ever. The car after we bought it has undergone some mechanical fixes the drive belt set has been changed, new front suspensions, new rear silent blocks, new clutch set and a gear linkage fix, new tires, oil change and the usual major look over. It threw us back money vise quite a bit but since we bought the car to use it day by day and to travel around in it safely I wanted it to be in shape. We've drove more than 8000 km's in it so far without any major fault. Mechanically it's rock solid. We drive it around town and on a freeway as well, it performs nicely, the consumption is perfectly normal and OK and it serves us well but...
But one little annoying problem came up from a month or so ago and I'm yet to find a solution for it.
The problem is that our Idle RPM variate's some 150rpm's which is so much that it can be felt even at low RPM's up to 1500 when accelerating. It does this on Petrol and LPG as well, it's felt less on Petrol and more on LPG but it's doing this RPM fluctuation (that's the perfect word for it) occasionally and for random amounts of time. It does this some time when cold or when at running temp, more on running temp and the RPM fluctuations are not constant this is the most strange thing to me, they come and go intermittently for some 30s to a minute then Idle RPM becomes rock solid again, then it's doing it again and so on...it's driving me nuts why is it doing it, the most annoying is when accelerating and the car's engine's RPM's are audibly fluctuating, it does not stall or shut down, it just fluctuates.
Fixes we tried so far:
1. Spark plug change - Nothing.
2. Intake valve complete clean and run through - Nothing
3. Used up 2 or 3 cans of various brand "magic" injector and carburetor cleaning petrol additive (Wurth, Wins, etc) and drove some 2000km's on petrol - The running is a bit smoother and quieter but the rpm fluctuations remain without change.
4. I bought an OBD2 tester just to check for engine faults - No registered Engine Faults or errors of any kind.
The car seems rock solid and working, I told you, we drove in it already some 8000 km's without any major hiccups except this very annoying RPM fluctuation at Idle and at low RPM's.
It has seen 2 mechanics so far, neither of them could tell me what's wrong, except that mechanically the car is sound and ideal. It went back to the LPG service where the LPG system was put it, they ran diagnostics and some basic check ups and of course they tell me the same that the system of theirs is working flawlessly and it's NOT the LPG system causing it.
They tell me it's obviously the dodgy Italian electronics somewhere in the car but they of course are not electronics themselves so they could not tell me more
I'm getting frustrated about this RPM fluctuation. We can still drive the car but it's annoying, it just begun to appear and it has not gone worse, it's just there, sometimes it makes the engine rev over or louder sometimes the rpm's are steady but more times it's not that's for sure.
Has anyone experienced anything like this so far? Does any one of you guys have similar Stilo with LPG in it and did anyone notice something like this? I'm in desperate need of help.
I really like the car
it serves us well and I feel if we take care of it, it will take care of us as well
but this annoying rpm fluctuation is yet to be fixed.
Any suggestions are welcome!
