Hi, The clutch on my stepdads 02 stilo 1.6 dynamic is slipping and close to going.I have said i will attempt it
,Was looking for a guide but can't find one for this engine.Is it similar to 1.3 punto Clutch change?,There is some on youtube for punto. I have got as far as removed battery,battery-tray,fuse box and wiring out the way.Was hoping the Sub frame and passenger side suspension strut don't need taking off?.Also the thermostat housing does this need removing?.
next i'm drain gearbox,Undo lower arm, track rod end,Drop link to remove driveshaft.Then i will Assess the rest after that.
Any Help/Tips would be grateful,I have 2 new driveshaft oil seals and and input shaft oil seal, Driveshaft seals i can do,The input shaft seal i need help on.
as Exhaust got to be unbolted.Also hope not but exhaust manifold,does this need removed?. any help be useful Thanks in advance
PS, do i really need alignment tool for re-install clutch or can i get away with tight fit socket or similar and eyesight?.
