Technical Stilo 1.2 and 1.4 - airbox & pipes
dtimmins1985
Established member
West Yorkshire
Afternoon guys,
Can anyone tell me...
I need to replace breather pipe from rocker cover to inlet pipe.
The little pipe that goes from the rocker to the inlet pipe that connects to the inlet manifold....
A while back i noticed it was split round the bit that slots onto the intake pipe, i secured it with a jubilee clip but its still leaking and you can hear the air leaking at low revs... so needs replacing.
I have found the part on ebay from a 1.4 16v stilo.
Will this fit the 1.2 - are they the same, it looks the same but wanted to make sure before i bought it.
Also, someone told me that this pipe has metered air that travels through it and it will cause issues when split - is this correct? i can hear a difference in noise at low revs and it sounds like air is escaping...
Any help is greatly appreciated.
thanks in advance.
